Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K02US Track pad Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: passo 1, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: passo 1, imagem 2 %32
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 3, imagem 2 %32
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: passo 4, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 5, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 5, imagem 3 %32
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 6, imagem 1 %32
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: passo 7, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: passo 7, imagem 2 %32
    • Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 8, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 8, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 8, imagem 3 %32
    • Remove the ribbon cable by lifting it out of the connector.
    • Lift the grey adhesive tape.
  9. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 9, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 9, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: passo 9, imagem 3 %32
    • Lift the track pad from the top.
    • Slide the track pad away from yourself to clear the black plastic edge.
    • Lift the track pad up and out of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 262
