Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Bottom Case: passo 1, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Bottom Case: passo 1, imagem 2 %32
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 3, imagem 2 %32
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Battery: passo 4, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 5, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 5, imagem 3 %32
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 6, imagem 1 %32
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: passo 7, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: passo 7, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement, Display Screen: passo 7, imagem 3 %32
    • Use the spudger to lift the hinge locking the gold colored display cable in place.
    • Slide the cable out to remove it from the motherboard.
  8. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 8, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 8, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 8, imagem 3 %32
    • Using the spudger, lift the adhesive securing the wireless card antenna wires.
    • Lift the white and black antenna wires with the spudger.
  9. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 9, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 9, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 9, imagem 3 %32
    • Remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
  10. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 10, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 10, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 10, imagem 3 %32
    • Once the hinge screws have been removed, open the laptop.
    • The laptop bottom will separate from the screen once you open it a certain amount.
  11. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 11, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 11, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 11, imagem 3 %32
    • Use the iFixit opening tool to pry in between the bezel and screen.
    • You will hear a snapping sound as you work your way around the bezel with the iFixit opening tool.
  12. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 12, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 12, imagem 2 %32
  13. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 13, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 13, imagem 2 %32
    • Using the spudger, lift the adhesive tape holding the display cable.
  14. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 14, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 14, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 14, imagem 3 %32
    • Gently lift the panel up and fold it over to expose the display cable on the backside of the display.
  15. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 15, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 15, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 15, imagem 3 %32
    • Use the spudger, lift the hinge locking the gold colored display cable in place.
    • Pull the cable away from you to slide it out of the monitor.
    • Be gentle around the display circuit board. It is labeled "Do not touch."
  16. Samsung Chromebook 3 XE500C13-K02US Display Screen Replacement: passo 16, imagem 1 %32
    • Once the display cable has been removed, lift the screen up and out of the case.
Conclusão
8 outras pessoas executaram este guia.
4 comentários
This also works for the XE500C13-K04US
Jonathan - Responder
It was more challenging than I thought. Reconnecting the antenna wires wasn’t easy. I needed better vision and dexterity to find it easier. Don’t forget to reuse the adhesive tape or you may be disappointed.
Bill Watson - Responder
Great guide!
Very accurate!
Joshua McVey - Responder
Just to confirm. You have to tear apart the bottom just to replace the led screen? Can't just remove the bezel?
Xe501c13-k02us
Trisha Kurtz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 2,009
