Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: passo 1, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: passo 1, imagem 2 %32
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 2, imagem 2 %32
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, imagem 2 %32 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, imagem 3 %32
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 4, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 4, imagem 2 %32
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 5, imagem 1 %32
    • Remove the hinges from the bar on both sides.
Conclusão
Uma outra pessoa concluiu este guia.
Caden Smith
Membro desde: 03/28/23
397 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Harley Spring 2023 Membro de IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 100
