Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: passo 1, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: passo 1, imagem 2 %32
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 3, imagem 2 %32
    • Remove the cover exposing the inside of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 367
