Introdução
This guide will explain how to replace your Samsung Chromebook 3 speakers. Before you begin you will need to remove the bottom case.
O que você precisa
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
Uma outra pessoa concluiu este guia.
