Ir para o conteúdo principal
Samsung Chromebook 3 Speakers Replacement
O que você precisa
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: passo 1, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement, Bottom Case: passo 1, imagem 2 %32
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement: passo 2, imagem 2 %32 Samsung Chromebook 3 Speakers Replacement: passo 2, imagem 3 %32
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: passo 3, imagem 1 %32
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: passo 4, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement, Speakers: passo 4, imagem 2 %32
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement: passo 5, imagem 2 %32 Samsung Chromebook 3 Speakers Replacement: passo 5, imagem 3 %32
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: passo 6, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement: passo 6, imagem 2 %32 Samsung Chromebook 3 Speakers Replacement: passo 6, imagem 3 %32
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: passo 7, imagem 1 %32 Samsung Chromebook 3 Speakers Replacement: passo 7, imagem 2 %32 Samsung Chromebook 3 Speakers Replacement: passo 7, imagem 3 %32
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Westberg
Membro desde: 03/11/19
23.116 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 515
