Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will show a step by step process to replace the display on the Samsung Chromebook 3. You will need to remove the bottom case and battery prior to replacing the display.
  1. Place the Chromebook face down so that the bottom case is exposed. Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook. You should hear a popping sound as the connectors disengage inside the case. You should hear a popping sound as the connectors disengage inside the case.
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Lift the case up and off the device
    • Lift the case up and off the device
  4. Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver. Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Use a spudger to gently pry the power cable cord upwards from the motherboard. Use a spudger to gently pry the power cable cord upwards from the motherboard.
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Lift the battery up and out from the case.
    • Lift the battery up and out from the case.
  7. Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers. Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers. Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
    • Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
  8. Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger. Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger. Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
    • Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
  9. Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it! Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
    • Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
  10. Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver. It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
    • Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
    • It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
  11. Open the laptop and remove the display.
    • Open the laptop and remove the display.
Conclusão
3 outras pessoas concluíram este guia.
Austin Blakely
Membro desde: 11/03/2019
4.785 Reputação
25 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
129 Membros
12.553 Guias de autoria
Any idea as to what kind of connector the display has to the motherboard? Or how many pins? Trying to tear down the display and see if I can use it as an extra monitor.
Sam Rall - Responder
It looks like there are 40 pins on the display connector. I’m not sure what it would be called or if it’s any kind of standard. If you do manage to convert the display to an extra monitor, you should definitely let us know though!
Austin Blakely -
Great guide - my 12 year old son was able to get through it with a little help from me. Nice work.
smo2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 35
Duração total: 628
