Ir para o conteúdo principal
Samsung Chromebook 2 XE503c12 Battery Replacement
O que você precisa
  1. Samsung Chromebook 2 XE503c12 Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung Chromebook 2 XE503c12 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Battery Replacement: passo 2, imagem 1 %32 Samsung Chromebook 2 XE503c12 Battery Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Battery Replacement: passo 3, imagem 1 %32 Samsung Chromebook 2 XE503c12 Battery Replacement: passo 3, imagem 2 %32
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Battery Replacement: passo 4, imagem 1 %32
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Battery Replacement: passo 5, imagem 1 %32
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 442
