Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    Make sure your Chromebook is turned off before you begin.
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver. Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver. Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Este passo não foi traduzido. Ajude a traduzi-lo
    Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer. Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    Once the cover is loose, remove the back cover panel using your hands. Once the cover is loose, remove the back cover panel using your hands.
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver. Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    Disconnect the wire that connects the battery to the motherboard by pulling upward. Disconnect the wire that connects the battery to the motherboard by pulling upward. Disconnect the wire that connects the battery to the motherboard by pulling upward.
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    Replace the back cover by clicking it into place with your hands. No need to replace the screws, this is just to protect the internal hardware while working on the screen.
    • Replace the back cover by clicking it into place with your hands.
    • No need to replace the screws, this is just to protect the internal hardware while working on the screen.
  8. Este passo não foi traduzido. Ajude a traduzi-lo
    Open the laptop and place it so that the back of the screen is laying on a flat surface. Insert a plastic opening tool between the front cover and plastic screen trim.
    • Open the laptop and place it so that the back of the screen is laying on a flat surface.
    • Insert a plastic opening tool between the front cover and plastic screen trim.
    • Work the plastic opening tool all around the trim.
    • Don't be afraid to use your hands to pull the trim from the front panel.
  9. Este passo não foi traduzido. Ajude a traduzi-lo
    Flip the computer over  so that the keys and screen are facing down. Insert the spudger between the back and front panel, at the hinge, and push the trim out.
    • Flip the computer over so that the keys and screen are facing down.
    • Insert the spudger between the back and front panel, at the hinge, and push the trim out.
  10. Este passo não foi traduzido. Ajude a traduzi-lo
    Place the laptop in a position where it is resting on the back of the screen.
    • Place the laptop in a position where it is resting on the back of the screen.
    • Remove the trim from the front panel by pulling up with your hands.
  11. Este passo não foi traduzido. Ajude a traduzi-lo
    Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place. Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place.
    • Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place.
  12. Este passo não foi traduzido. Ajude a traduzi-lo
    Using the spudger, pry the screen loose from the front panel. Do not try to remove the screen yet, it is still connect by a wire.
    • Using the spudger, pry the screen loose from the front panel.
    • Do not try to remove the screen yet, it is still connect by a wire.
  13. Este passo não foi traduzido. Ajude a traduzi-lo
    Place the laptop in an upright position. When you place the Chromebook in this position the screen may fall off, so make sure to hold onto it. Pull back the screen to locate the LCD cable, and disconnect it by pulling the black tape that surrounds it towards you.
    • Place the laptop in an upright position.
    • When you place the Chromebook in this position the screen may fall off, so make sure to hold onto it.
    • Pull back the screen to locate the LCD cable, and disconnect it by pulling the black tape that surrounds it towards you.
  14. Este passo não foi traduzido. Ajude a traduzi-lo
    Pull the screen from the front panel using your hands to fully remove it.
    • Pull the screen from the front panel using your hands to fully remove it.
Linha de Chegada
10 outras pessoas concluíram este guia.
MacKenzie Colson
Membro desde: 25/01/2016
583 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-3, Rose Winter 2016 Membro de UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Duração total: 5,598
