Introdução
You may need to perform this replacement if your Chromebook 2 has a faulty screen, resulting in display issues. Ensure your device is powered off before beginning this replacement.
In order to reduce shock hazard during this replacement, the steps to remove the battery are included as a prerequisite.
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
10 outras pessoas concluíram este guia.
