Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
If one of your keys is no longer working, follow this guide and learn how to successfully replace a broken key cap or gain access to clean underneath it.
Peças
Nenhum componente especificado.
  1. Using a plastic opening tool, place it beneath the key in question and pry it off. Using a plastic opening tool, place it beneath the key in question and pry it off.
    • Using a plastic opening tool, place it beneath the key in question and pry it off.
  2. Remove the key fully from the board.
    • Remove the key fully from the board.
  3. Place a new key in the same orientation as the other keys.
    • Place a new key in the same orientation as the other keys.
    • Use your index finger to apply pressure onto the key until it clicks into place.
Conclusão
2 outras pessoas concluíram este guia.
Alex Edwards
Membro desde: 01/02/2016
125 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-3, Rose Winter 2016 Membro de UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Membros
4 Guias de autoria
i tried this but a key stopped sticking to the board
darkclawsthenightwing - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 674
