Ir para o conteúdo principal
Samsung Chromebook series 5 XE550C22 SSD Replacement
O que você precisa
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: passo 1, imagem 2 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 2, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 2, imagem 2 %32
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 3, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 3, imagem 2 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 3, imagem 3 %32
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 4, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 4, imagem 2 %32
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: passo 5, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 6, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 6, imagem 2 %32
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: passo 7, imagem 1 %32
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 8, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 8, imagem 2 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 8, imagem 3 %32
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 9, imagem 1 %32 Samsung Chromebook series 5 XE550C22 SSD Replacement: passo 9, imagem 2 %32
    • Pull the SSD up and away from the Chromebook
Conclusão
4 outras pessoas executaram este guia.
Abel Osorio
Membro desde: 09/11/17
330 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
Membros da 3
Autoria de 14 guias
4 comentários
Hello where can I get I higher SSD to buy
aduboa moses - Responder
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - Responder
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - Responder
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 5,073
