Introdução
The speaker is easily damaged by playing music too loud. This part is easily replaced.
O que você precisa
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
11 outras pessoas executaram este guia.
