Ir para o conteúdo principal
Samsung Captivate Rear Case Replacement
O que você precisa
  1. Samsung Captivate Rear Case Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: passo 2, imagem 1 %32
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: passo 3, imagem 1 %32
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: passo 4, imagem 1 %32
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: passo 5, imagem 1 %32
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: passo 6, imagem 1 %32 Samsung Captivate Rear Case Replacement: passo 6, imagem 2 %32 Samsung Captivate Rear Case Replacement: passo 6, imagem 3 %32
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: passo 7, imagem 1 %32
    • Separate the rear case from the phone.
Conclusão
12 outras pessoas executaram este guia.
Christopher
Membro desde: 10/06/11
643 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 20-25, Maness Fall 2011 Membro de Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 3,568
