Ir para o conteúdo principal
Samsung Captivate Glide Speaker Replacement
O que você precisa
  1. Samsung Captivate Glide Speaker Replacement, Motherboard: passo 1, imagem 1 %32 Samsung Captivate Glide Speaker Replacement, Motherboard: passo 1, imagem 2 %32 Samsung Captivate Glide Speaker Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Speaker Replacement: passo 2, imagem 1 %32 Samsung Captivate Glide Speaker Replacement: passo 2, imagem 2 %32
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Speaker Replacement: passo 3, imagem 1 %32 Samsung Captivate Glide Speaker Replacement: passo 3, imagem 2 %32
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Speaker Replacement: passo 4, imagem 1 %32 Samsung Captivate Glide Speaker Replacement: passo 4, imagem 2 %32 Samsung Captivate Glide Speaker Replacement: passo 4, imagem 3 %32
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Speaker Replacement: passo 5, imagem 1 %32 Samsung Captivate Glide Speaker Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Speaker Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Speaker Replacement: passo 7, imagem 1 %32
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Speaker Replacement: passo 8, imagem 1 %32 Samsung Captivate Glide Speaker Replacement: passo 8, imagem 2 %32
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Speaker Replacement, Speaker: passo 9, imagem 1 %32
    • Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
  10. Samsung Captivate Glide Speaker Replacement: passo 10, imagem 1 %32
    • Remove speaker manually.
    • There is nothing connecting it to the motherboard, so just pull.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Mira
Membro desde: 09/23/14
289 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-3, Mcgee Fall 2014 Membro de USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 413
