Ir para o conteúdo principal
Samsung Captivate Earpiece Replacement
O que você precisa
  1. Samsung Captivate Earpiece Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Earpiece Replacement: passo 2, imagem 1 %32
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Earpiece Replacement: passo 3, imagem 1 %32
    • Replace the old battery with the new one.
  4. Samsung Captivate Earpiece Replacement, Rear Case: passo 4, imagem 1 %32
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Earpiece Replacement: passo 5, imagem 1 %32
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Earpiece Replacement: passo 6, imagem 1 %32 Samsung Captivate Earpiece Replacement: passo 6, imagem 2 %32 Samsung Captivate Earpiece Replacement: passo 6, imagem 3 %32
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Earpiece Replacement: passo 7, imagem 1 %32
    • Separate the rear case from the phone.
  8. Samsung Captivate Earpiece Replacement, Antenna Cable: passo 8, imagem 1 %32 Samsung Captivate Earpiece Replacement, Antenna Cable: passo 8, imagem 2 %32
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Earpiece Replacement, Camera Assembly: passo 9, imagem 1 %32
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Samsung Captivate Earpiece Replacement: passo 10, imagem 1 %32
    • Gently lift the camera assembly out of the plastic housing.
  11. Samsung Captivate Earpiece Replacement, Motherboard: passo 11, imagem 1 %32 Samsung Captivate Earpiece Replacement, Motherboard: passo 11, imagem 2 %32 Samsung Captivate Earpiece Replacement, Motherboard: passo 11, imagem 3 %32
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  12. Samsung Captivate Earpiece Replacement: passo 12, imagem 1 %32
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  13. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: passo 13, imagem 1 %32 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: passo 13, imagem 2 %32
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  14. Samsung Captivate Earpiece Replacement, Earpiece: passo 14, imagem 1 %32
    • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
Conclusão
Drew Bentz
Membro desde: 09/22/11
565 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 20-25, Maness Fall 2011 Membro de Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,369
