Ir para o conteúdo principal
Samsung Captivate Antenna Cable Replacement
O que você precisa
  1. Samsung Captivate Antenna Cable Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Antenna Cable Replacement: passo 2, imagem 1 %32
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Antenna Cable Replacement: passo 3, imagem 1 %32
    • Replace the old battery with the new one.
  4. Samsung Captivate Antenna Cable Replacement, Rear Case: passo 4, imagem 1 %32
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Antenna Cable Replacement: passo 5, imagem 1 %32
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Antenna Cable Replacement: passo 6, imagem 1 %32 Samsung Captivate Antenna Cable Replacement: passo 6, imagem 2 %32 Samsung Captivate Antenna Cable Replacement: passo 6, imagem 3 %32
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Antenna Cable Replacement: passo 7, imagem 1 %32
    • Separate the rear case from the phone.
  8. Samsung Captivate Antenna Cable Replacement, Antenna Cable: passo 8, imagem 1 %32 Samsung Captivate Antenna Cable Replacement, Antenna Cable: passo 8, imagem 2 %32
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
Conclusão
7 outras pessoas executaram este guia.
Drew Bentz
Membro desde: 09/22/11
565 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 20-25, Maness Fall 2011 Membro de Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
Membros da 3
Autoria de 9 guias
2 comentários
Quick question, is this the antenna for wifi or cellular network?
Michael Perdomo - Responder
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
Drew Bentz -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 3,611
