Introdução
Use this guide to replace your captivates 3.5mm headphone jack.
O que você precisa
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Using the spudger slide the tool under the three highlighted connectors to begin disconnection
Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
Be careful when reassembling rear cover as there are 2 tabs at the top of the case that can easily bend and eventually crack of giving no support to the top closure.
7 outras pessoas executaram este guia.
Um comentário
Between steps 7 and 8, there are a number of steps missing, including the removal of the camera, and the removal of the speaker assembly.
These can be found on the "Mother Board" repair manual, back on the device page.
~Desmond
