Ir para o conteúdo principal
Samsung CLP-300 Imaging Unit Replacement
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: passo 1, imagem 1 %32
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: passo 2, imagem 1 %32 Samsung CLP-300 Imaging Unit Replacement: passo 2, imagem 2 %32
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: passo 3, imagem 1 %32
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: passo 4, imagem 1 %32 Samsung CLP-300 Imaging Unit Replacement: passo 4, imagem 2 %32 Samsung CLP-300 Imaging Unit Replacement: passo 4, imagem 3 %32
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
Conclusão
Heather Howard
Membro desde: 10/15/14
586 Reputação
Autoria de 4 guias
Equipe
University of Maine, Team 1-1, Diaz Fall 2014 Membro de University of Maine, Team 1-1, Diaz Fall 2014
UMAINE-DIAZ-F14S1G1
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 13,139
