Ir para o conteúdo principal
Samsung Brightside Logic board Replacement
O que você precisa
  1. Samsung Brightside Logic board Replacement, Logic board: passo 1, imagem 1 %32 Samsung Brightside Logic board Replacement, Logic board: passo 1, imagem 2 %32 Samsung Brightside Logic board Replacement, Logic board: passo 1, imagem 3 %32
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: passo 2, imagem 1 %32 Samsung Brightside Logic board Replacement: passo 2, imagem 2 %32 Samsung Brightside Logic board Replacement: passo 2, imagem 3 %32
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: passo 3, imagem 1 %32 Samsung Brightside Logic board Replacement: passo 3, imagem 2 %32 Samsung Brightside Logic board Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: passo 4, imagem 1 %32 Samsung Brightside Logic board Replacement: passo 4, imagem 2 %32 Samsung Brightside Logic board Replacement: passo 4, imagem 3 %32
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: passo 5, imagem 1 %32 Samsung Brightside Logic board Replacement: passo 5, imagem 2 %32
    • Detach the LCD connector.
    • Remove the logic board
Conclusão
Uma outra pessoa concluiu este guia.
oldturkey03
Membro desde: 09/29/10
782.076 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 537 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,513
