Ir para o conteúdo principal
Samsung Blast Keyboard Replacement
O que você precisa
  1. Samsung Blast Keyboard Replacement, At a Glance: passo 1, imagem 1 %32 Samsung Blast Keyboard Replacement, At a Glance: passo 1, imagem 2 %32
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: passo 2, imagem 1 %32 Samsung Blast Keyboard Replacement, Battery Case Removal: passo 2, imagem 2 %32
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: passo 3, imagem 1 %32
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: passo 4, imagem 1 %32 Samsung Blast Keyboard Replacement, Back Case Removal: passo 4, imagem 2 %32
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: passo 5, imagem 1 %32 Samsung Blast Keyboard Replacement, Button Pads: passo 5, imagem 2 %32
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: passo 6, imagem 1 %32 Samsung Blast Keyboard Replacement, Motherboard Removal: passo 6, imagem 2 %32 Samsung Blast Keyboard Replacement, Motherboard Removal: passo 6, imagem 3 %32
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: passo 7, imagem 1 %32 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: passo 7, imagem 2 %32
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Conclusão
Jordan Taylor
Membro desde: 02/11/14
10 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Buehl Spring 2014 Membro de Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 398
