Ir para o conteúdo principal
Samsung Blast Back Cover Replacement
O que você precisa
  1. Samsung Blast Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: passo 2, imagem 1 %32
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: passo 3, imagem 1 %32
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: passo 4, imagem 1 %32
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 204
