Ir para o conteúdo principal
Samsung Blackjack Back Phone Casing Replacement
O que você precisa
  1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: passo 1, imagem 1 %32 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: passo 1, imagem 2 %32 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: passo 1, imagem 3 %32
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Back Phone Casing Replacement, Battery: passo 2, imagem 1 %32 Samsung Blackjack Back Phone Casing Replacement, Battery: passo 2, imagem 2 %32
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Back Phone Casing Replacement, SIM Card: passo 3, imagem 1 %32 Samsung Blackjack Back Phone Casing Replacement, SIM Card: passo 3, imagem 2 %32 Samsung Blackjack Back Phone Casing Replacement, SIM Card: passo 3, imagem 3 %32
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: passo 4, imagem 1 %32 Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: passo 4, imagem 2 %32
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Back Phone Casing Replacement: passo 5, imagem 1 %32 Samsung Blackjack Back Phone Casing Replacement: passo 5, imagem 2 %32 Samsung Blackjack Back Phone Casing Replacement: passo 5, imagem 3 %32
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Conclusão
Kristin Manna
Membro desde: 10/22/12
29 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 14-4, Benson Fall 2012 Membro de Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 520
