Ir para o conteúdo principal
Samsung BD-JM57C Wi-Fi Card Replacement
O que você precisa
  1. Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: passo 1, imagem 1 %32 Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: passo 1, imagem 2 %32
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: passo 2, imagem 1 %32 Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: passo 2, imagem 2 %32
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Wi-Fi Card Replacement: passo 3, imagem 1 %32 Samsung BD-JM57C Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: passo 4, imagem 1 %32 Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: passo 4, imagem 2 %32
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 251
