Ir para o conteúdo principal
Samsung BD-JM57C Motherboard Replacement
O que você precisa
  1. Samsung BD-JM57C Motherboard Replacement, Top Cover: passo 1, imagem 1 %32 Samsung BD-JM57C Motherboard Replacement, Top Cover: passo 1, imagem 2 %32
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Motherboard Replacement, Disc Drive: passo 2, imagem 1 %32 Samsung BD-JM57C Motherboard Replacement, Disc Drive: passo 2, imagem 2 %32
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Motherboard Replacement: passo 3, imagem 1 %32 Samsung BD-JM57C Motherboard Replacement: passo 3, imagem 2 %32
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Motherboard Replacement, Power Cord: passo 4, imagem 1 %32 Samsung BD-JM57C Motherboard Replacement, Power Cord: passo 4, imagem 2 %32
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  5. Samsung BD-JM57C Motherboard Replacement: passo 5, imagem 1 %32
    • Push in the small white lever and pull it towards you to release the cord.
  6. Samsung BD-JM57C Motherboard Replacement: passo 6, imagem 1 %32
    • Move the power cord out from under the metal tab on the side of the case.
  7. Samsung BD-JM57C Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  8. Samsung BD-JM57C Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  9. Samsung BD-JM57C Motherboard Replacement: passo 9, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  10. Samsung BD-JM57C Motherboard Replacement: passo 10, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 521
