Ir para o conteúdo principal
Samsung BD-H5100 Disk Reader Replacement
O que você precisa
  1. Samsung BD-H5100 Disk Reader Replacement, Disk Reader: passo 1, imagem 1 %32
    • Use the Phillips Head #2 screwdriver to remove the three 10 mm screws on the back panel.
  2. Samsung BD-H5100 Disk Reader Replacement: passo 2, imagem 1 %32 Samsung BD-H5100 Disk Reader Replacement: passo 2, imagem 2 %32 Samsung BD-H5100 Disk Reader Replacement: passo 2, imagem 3 %32
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Disk Reader Replacement: passo 3, imagem 1 %32 Samsung BD-H5100 Disk Reader Replacement: passo 3, imagem 2 %32
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Disk Reader Replacement: passo 4, imagem 1 %32
    • Remove the two 7.5 mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Disk Reader Replacement: passo 5, imagem 1 %32 Samsung BD-H5100 Disk Reader Replacement: passo 5, imagem 2 %32
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Disk Reader Replacement: passo 6, imagem 1 %32
    • Flip the disk tray upside down.
  7. Samsung BD-H5100 Disk Reader Replacement: passo 7, imagem 1 %32
    • Use the Phillips Head #00 screwdriver to remove the four 6.2 mm corner screws.
  8. Samsung BD-H5100 Disk Reader Replacement: passo 8, imagem 1 %32
    • Flip the disk reader up like a flip phone.
    • Be careful not to break the ribbon.
  9. Samsung BD-H5100 Disk Reader Replacement: passo 9, imagem 1 %32 Samsung BD-H5100 Disk Reader Replacement: passo 9, imagem 2 %32
    • Pull the ribbon out gently from one corner by the blue tab.
Conclusão
Uma outra pessoa concluiu este guia.
Mira Patel
Membro desde: 10/11/16
580 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Leahy Fall 2016 Membro de USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 627
