Ir para o conteúdo principal
Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
O que você precisa
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: passo 1, imagem 1 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: passo 1, imagem 2 %32
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 2, imagem 1 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 2, imagem 2 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 2, imagem 3 %32
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 3, imagem 1 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 3, imagem 2 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 3, imagem 3 %32
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 4, imagem 1 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 4, imagem 2 %32 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: passo 4, imagem 3 %32
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 682
