Ir para o conteúdo principal
Samsung BD-F5900 Power Supply Replacement
O que você precisa
  1. Samsung BD-F5900 Power Supply Replacement, Top Cover: passo 1, imagem 1 %32
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Power Supply Replacement: passo 2, imagem 1 %32
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Power Supply Replacement, Power Supply: passo 3, imagem 1 %32 Samsung BD-F5900 Power Supply Replacement, Power Supply: passo 3, imagem 2 %32
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Power Supply Replacement: passo 4, imagem 1 %32
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Power Supply Replacement: passo 5, imagem 1 %32 Samsung BD-F5900 Power Supply Replacement: passo 5, imagem 2 %32 Samsung BD-F5900 Power Supply Replacement: passo 5, imagem 3 %32
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
Conclusão
Louis McKean
Membro desde: 10/18/17
528 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G21, Cagle Fall 2017 Membro de USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 228
