Ir para o conteúdo principal
Samsung BD-F5900 DVD Disc Tray Replacement
O que você precisa
  1. Samsung BD-F5900 DVD Disc Tray Replacement, Top Cover: passo 1, imagem 1 %32
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 DVD Disc Tray Replacement: passo 2, imagem 1 %32
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 DVD Disc Tray Replacement, DVD Disc Tray: passo 3, imagem 1 %32
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  4. Samsung BD-F5900 DVD Disc Tray Replacement: passo 4, imagem 1 %32
    • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  5. Samsung BD-F5900 DVD Disc Tray Replacement: passo 5, imagem 1 %32
    • Push two small prongs on either side of disc tray inwards and push disc tray forward.
  6. Samsung BD-F5900 DVD Disc Tray Replacement: passo 6, imagem 1 %32
    • Remove disc tray
Conclusão
Uma outra pessoa concluiu este guia.
Louis McKean
Membro desde: 10/18/17
528 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G21, Cagle Fall 2017 Membro de USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 653
