Introdução
Is your Blu-ray player not able to play your favorite flicks due to a faulty disc drive? If so, all you need is a #1 Phillips screwdriver and this guide to show how to replace the DVD disc tray with a new one.
O que você precisa
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
Uma outra pessoa concluiu este guia.
