Ir para o conteúdo principal
Samsung BD-F5700 Power Cord Replacement
O que você precisa
  1. Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32 Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, imagem 3 %32
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Power Cord Replacement: passo 2, imagem 1 %32 Samsung BD-F5700 Power Cord Replacement: passo 2, imagem 2 %32 Samsung BD-F5700 Power Cord Replacement: passo 2, imagem 3 %32
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Power Cord Replacement: passo 3, imagem 1 %32 Samsung BD-F5700 Power Cord Replacement: passo 3, imagem 2 %32
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Power Cord Replacement: passo 4, imagem 1 %32
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membro de USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 284
