Ir para o conteúdo principal
Samsung BD-F5700 DC Power Board Replacement
O que você precisa
  1. Samsung BD-F5700 DC Power Board Replacement, DC Power Board: passo 1, imagem 1 %32
    • Remove the three 10mm screws with a Phillips #0 screwdriver.
    • Pry the top off with a plastic opening tool.
  2. Samsung BD-F5700 DC Power Board Replacement: passo 2, imagem 1 %32
    • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  3. Samsung BD-F5700 DC Power Board Replacement: passo 3, imagem 1 %32
    • Lift up the power cord at its base to remove it.
  4. Samsung BD-F5700 DC Power Board Replacement: passo 4, imagem 1 %32
    • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  5. Samsung BD-F5700 DC Power Board Replacement: passo 5, imagem 1 %32
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    • Grip the blue tab attached to the base and pull upwards.
  6. Samsung BD-F5700 DC Power Board Replacement: passo 6, imagem 1 %32
    • Grip the edges of the motherboard and pull upwards to remove.
Conclusão
samer odeh
Membro desde: 02/13/18
313 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membro de USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 370
