Ir para o conteúdo principal
Samsung BD-E5400 Power Cord Replacement
O que você precisa
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: passo 1, imagem 1 %32 Samsung BD-E5400 Power Cord Replacement, Outer Cover: passo 1, imagem 2 %32
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: passo 2, imagem 1 %32
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: passo 3, imagem 1 %32 Samsung BD-E5400 Power Cord Replacement, Power Cord: passo 3, imagem 2 %32
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: passo 4, imagem 1 %32 Samsung BD-E5400 Power Cord Replacement: passo 4, imagem 2 %32 Samsung BD-E5400 Power Cord Replacement: passo 4, imagem 3 %32
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
Conclusão
Cameron Herring
Membro desde: 08/28/18
306 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G3, Arle Fall 2018 Membro de IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 379
