Ir para o conteúdo principal
Samsung BD-D5500 Power Supply Replacement
O que você precisa
  1. Samsung BD-D5500 Power Supply Replacement, Samsung BD-D5500 Disassembly: passo 1, imagem 1 %32
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Power Supply Replacement: passo 2, imagem 1 %32 Samsung BD-D5500 Power Supply Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Power Supply Replacement, Power Supply: passo 3, imagem 1 %32
    • Unscrew the 1.2mm screws labeled with a red circle and remove the power supply from the player.
  4. Samsung BD-D5500 Power Supply Replacement: passo 4, imagem 1 %32
    • Labeled with a red rectangle is the location where they are connected. Grab the motherboard in one hand and the power supply in the other, and pull the motherboard up and push the power supply down. The motherboard and power supply should then disconnect.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 446
