Pular para o conteúdo principal
Introdução
This is a replacement guide for the Samsung BD-D5500 Blu-ray player. This guide will personally give you the information you need to replace the disc tray of the device. This is a very easy and simple process.
Peças
Nenhum componente especificado.
  1. To begin, turn the device over so that the bottom is facing up. There are  9 black clips that attach the plastic body to the case.  Remove these clips from the case.
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device.  This will allow you to remove the cover. This is how your device will look after you remove the top.
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. To remove the disc hub all you have to do is remove the 4 screws holding it down.
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. To replace the disc tray open the disk hub and unsnap the sides of the device.
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Locate the slider that reads open and close.
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Return it face up and the disc tray will slide out.
    • Return it face up and the disc tray will slide out.
Conclusão
Brandon Nelson
Membro desde: 29-01-2018
109 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Todo: 228
