Ir para o conteúdo principal
Samsung Admire Speaker Replacement
O que você precisa
  1. Samsung Admire Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: passo 2, imagem 1 %32
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: passo 3, imagem 1 %32 Samsung Admire Speaker Replacement, Remove the screws: passo 3, imagem 2 %32 Samsung Admire Speaker Replacement, Remove the screws: passo 3, imagem 3 %32
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: passo 4, imagem 1 %32 Samsung Admire Speaker Replacement, Inside back cover: passo 4, imagem 2 %32 Samsung Admire Speaker Replacement, Inside back cover: passo 4, imagem 3 %32
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: passo 5, imagem 1 %32 Samsung Admire Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
Conclusão
Thao Uyen Do
Membro desde: 01/20/15
914 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membro de USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 785
