Ir para o conteúdo principal
Samsung Admire Camera Replacement
O que você precisa
  1. Samsung Admire Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Samsung Admire Camera Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  3. Samsung Admire Camera Replacement, Remove the screws: passo 3, imagem 1 %32 Samsung Admire Camera Replacement, Remove the screws: passo 3, imagem 2 %32 Samsung Admire Camera Replacement, Remove the screws: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
  4. Samsung Admire Camera Replacement, Inside back Cover: passo 4, imagem 1 %32 Samsung Admire Camera Replacement, Inside back Cover: passo 4, imagem 2 %32 Samsung Admire Camera Replacement, Inside back Cover: passo 4, imagem 3 %32
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
  5. Samsung Admire Camera Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Admire Camera Replacement, Motherboard: passo 5, imagem 2 %32 Samsung Admire Camera Replacement, Motherboard: passo 5, imagem 3 %32
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
  6. Samsung Admire Camera Replacement, Camera: passo 6, imagem 1 %32 Samsung Admire Camera Replacement, Camera: passo 6, imagem 2 %32
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
Conclusão
12 outras pessoas executaram este guia.
Thao Uyen Do
Membro desde: 01/20/15
926 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membro de USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 1,802
