Introdução
The front speaker is the speaker pressed to your ear when you are talking on the phone with someone. If the noise emitted from this speaker is distorted or if no noise is emitted at all, then installing a new speaker may help alleviate these issues.
O que você precisa
To remove the back casing, firmly press down and push towards the bottom of the phone.
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Uma outra pessoa concluiu este guia.
