Introdução
Before beginning be sure you have the iFixIt tool kit and magnet mat as the screws can be very small. The Wi-Fi card is what allows the computer to be able to access the internet wirelessly and is very easy to replace.
O que você precisa
Turn the laptop upside down so that the underside of the laptop is facing you.
Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
Quase terminado!
Conclusão
