Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Speakers Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: passo 3, imagem 2 %32
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Speakers Replacement: passo 4, imagem 2 %32
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: passo 5, imagem 1 %32
    • Gently tug on the white connector in order to remove the speakers.
Conclusão
Karoline DaVee
Membro desde: 03/20/15
136 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 2-3, Grigsby Spring 2015 Membro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,482
