Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Screen Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Screen Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Screen Replacement, Screen: passo 3, imagem 1 %32
    • Disconnect the wire connected at the marked location. This is done by giving it a solid tug parallel with the laptop.
  4. Samsung ATIV Book 9 Plus Screen Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Screen Replacement: passo 4, imagem 2 %32
    • Unscrew the three 4.3 mm screws by using a #000 screwdriver located on the hinges in both corners of the laptop.
  5. Samsung ATIV Book 9 Plus Screen Replacement: passo 5, imagem 1 %32 Samsung ATIV Book 9 Plus Screen Replacement: passo 5, imagem 2 %32
    • Remove the piece of foam that covers two antenna cable connectors.
    • Use the tip of a spudger or a fingernail to pry straight up and disconnect the antenna cable connectors.
  6. Samsung ATIV Book 9 Plus Screen Replacement: passo 6, imagem 1 %32
    • Now the screen is completely disconnected and can just be lifted off.
Conclusão
Uma outra pessoa concluiu este guia.
Casey Kauffman
Membro desde: 11/06/17
329 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S6-G6, Baechle Fall 2017 Membro de IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 2,171
