Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Internal Fans Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, imagem 2 %32 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, imagem 3 %32
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 4, imagem 2 %32
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 5, imagem 1 %32
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
Conclusão
Rhannie Surel
Membro desde: 03/20/15
137 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 2-3, Grigsby Spring 2015 Membro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
Membros da 4
Autoria de 4 guias
Um comentário
I think that's to easy!
Ocean - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 4,429
