Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, imagem 2 %32 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, imagem 3 %32
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 4, imagem 2 %32
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 5, imagem 1 %32
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: passo 6, imagem 1 %32
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 7, imagem 1 %32
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 8, imagem 1 %32
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Conclusão
Ryan Smith
Membro desde: 04/01/19
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S7-G7, Wilson Spring 2019 Membro de IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 647
