Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Charger Port Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: passo 3, imagem 2 %32
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 4, imagem 1 %32
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 5, imagem 1 %32
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 6, imagem 1 %32
    • Remove the disconnected charger port.
Conclusão
3 outras pessoas executaram este guia.
Casey Kauffman
Membro desde: 11/06/17
329 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S6-G6, Baechle Fall 2017 Membro de IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,914
