Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Battery Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Battery Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 3 %32
    • Unscrew the four 4.55 mm Phillips #000 screws on the edges of the battery.
  4. Samsung ATIV Book 9 Plus Battery Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement: passo 4, imagem 2 %32
    • Lift to remove the battery from the laptop.
    • Place in the new battery to match the edges located on the laptop. Push on the top edge of the battery to secure it in place.
Conclusão
7 outras pessoas executaram este guia.
Nidhi Patel
Membro desde: 03/20/15
271 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 2-3, Grigsby Spring 2015 Membro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
Membros da 4
Autoria de 4 guias
4 comentários
Could you point to the RAM modules in the pictures please
rerof - Responder
http://www.myfixguide.com/manual/samsung...
There are no RAM modules. They are welded in the mother board.
Best regards!
Raul Lacavex -
any updated amazon product?
amitshalem - Responder
I just bought and installed this battery from Amazon: https://www.amazon.com/gp/product/B07NW7...
Mark Wolfman -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 12,675
