Ir para o conteúdo principal
Samsung ATIV Book 9 Lite Hard Drive Replacement
O que você precisa
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 2, imagem 1 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 2, imagem 2 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 2, imagem 3 %32
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 3, imagem 1 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 3, imagem 2 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 3, imagem 3 %32
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Lite Hard Drive Replacement: passo 4, imagem 2 %32
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
Conclusão
Phat Tran
Membro desde: 09/16/18
786 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 53
Duração total: 4,579
