Ir para o conteúdo principal
Samsung ATIV Book 9 Lite Battery Replacement
O que você precisa
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung ATIV Book 9 Lite Battery Replacement, Battery: passo 1, imagem 2 %32
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: passo 2, imagem 1 %32 Samsung ATIV Book 9 Lite Battery Replacement: passo 2, imagem 2 %32 Samsung ATIV Book 9 Lite Battery Replacement: passo 2, imagem 3 %32
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: passo 3, imagem 1 %32 Samsung ATIV Book 9 Lite Battery Replacement: passo 3, imagem 2 %32 Samsung ATIV Book 9 Lite Battery Replacement: passo 3, imagem 3 %32
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Lite Battery Replacement: passo 4, imagem 2 %32
    • Using your hands remove the battery from the computer.
Conclusão
3 outras pessoas executaram este guia.
Phat Tran
Membro desde: 09/16/18
786 Reputação
Autoria de 5 guias
Equipe
2 comentários
please where can i get the battery 🔋
Bethel Ugwudike - Responder
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 1,691
