Ir para o conteúdo principal
Samsung ATIV Book 9 Lite Audio Port Replacement
O que você precisa
  1. Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: passo 1, imagem 1 %32 Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: passo 1, imagem 2 %32
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Audio Port Replacement: passo 2, imagem 1 %32 Samsung ATIV Book 9 Lite Audio Port Replacement: passo 2, imagem 2 %32 Samsung ATIV Book 9 Lite Audio Port Replacement: passo 2, imagem 3 %32
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Audio Port Replacement: passo 3, imagem 1 %32 Samsung ATIV Book 9 Lite Audio Port Replacement: passo 3, imagem 2 %32 Samsung ATIV Book 9 Lite Audio Port Replacement: passo 3, imagem 3 %32
    • Using your hands move the black and white wires that are layered on top of the board to be out of the way of the removal.
    • Using a Phillips #0, remove three 3.5mm screws.
  4. Samsung ATIV Book 9 Lite Audio Port Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Lite Audio Port Replacement: passo 4, imagem 2 %32
    • Using your hands remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands, remove the board from the computer.
Conclusão
Phat Tran
Membro desde: 09/16/18
786 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 493
