Ir para o conteúdo principal
Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement
O que você precisa
  1. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: passo 1, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: passo 1, imagem 2 %32
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 2, imagem 1 %32
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Battery: passo 3, imagem 1 %32
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: passo 5, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: passo 5, imagem 2 %32
    • Disconnect the ribbon connecting the motherboard with the USB ports .
    • Disconnect the speaker from the board
  6. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 6, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 6, imagem 2 %32
    • Unscrew the 5mm screws with the Phillips #0 screw driver.
    • Lift the board out of the laptop.
Conclusão
Jonathan Robidoux
Membro desde: 03/22/19
196 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 258
