Ir para o conteúdo principal
Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement
O que você precisa
  1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: passo 1, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: passo 1, imagem 2 %32
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 2, imagem 1 %32
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Battery: passo 3, imagem 1 %32
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Track Pad: passo 5, imagem 1 %32
    • Disconnect the track pad from the motherboard.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 6, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 6, imagem 2 %32
    • Peel the tape on the track pad back.
    • Unscrew the five 2mm screws with the Phillips #0 screwdriver.
    • Rotate the track pad out of the case.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Robidoux
Membro desde: 03/22/19
196 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 240
